Thread inserts
john W.
12-03-2001 17:49:32
Hi, Does anyone out there have any experiences with thread inserts? I'd like to know which ones work the best, which are the easiest to use.thanks!
Donny-B
12-05-2001 17:52:01
 Re: thread inserts in reply to john W., 12-03-2001 17:49:32
Threaded inserts work well in most places. They can provide a water tight seal when used with locktite. One disadvantage is their size. A helicoil can be fit in parts with a thin wall thickness and most threaded inserts require a much larger threaded hole then the original bolt size. A great source for threaded inserts is McMaster-Carr Supply Company.
HMan
12-05-2001 17:26:02
Yep, far better than helicoils. I use them often at work. I like the ones with the locks you drive in and then break off. I've also had good luck with the ones you use the permanent locktite on. When I need an odd size,I get a piece of all-thread big enough,chuck it in the lathe and drill and tap it to the size I need,then use the permanent locktite. My tractors are full of them! HMan
Larry E
12-03-2001 18:54:53
Thread inserts are easier and simpler to use,you do not need special drills and taps.Helicoils require special taps and drills that are good for nothing else. Inserts can be replaced easily,or locked with locktite and heated slightly to remove
