Question about a 720
john w.
12-03-2001 17:45:25
Hi, I have a 720 gas JD. It has a fuel line running from the back of the tank to the sediment bulb then to carb. But There is another short line running from the front end of the fuel tank directly into the carb. Does anyone know why it has two fuel lines? Somebody took a piece of wire and pinched off the fuel going through the short line. The tractor runs fine. thank for your time and opinion.
Clooney
12-03-2001 19:37:56
 Re: Question about a 720 in reply to john w., 12-03-2001 17:45:25
John, that line is a vapor return line & is used to help prevent vapor lock. It will probably run ok with it pinched off as the early tractors didn't use that line, it will just have a greater chance of vapor lock in hot weather under high load.
