JD B shift lever
Doug
12-03-2001 15:57:05
I was pulling logs with my 48 b and went to shift from rev. to 3rd and the trans locked up. After wrestling with the shifter I got it unlocked but it was still in rev. with the shifter in the neutral position. The shifter seemed real loose down inside the trany. Seemed like I could almost pull it out. Would appriciate some expert advise before I dig in and drop something down in the the gear box. Thanks Doug
Chuck
12-03-2001 20:12:18
 Re: JD B shift lever in reply to Doug, 12-03-2001 15:57:05
you must have loosened the key that holds the shifter in place. Is a ring around the shaft and now the shifter is going down into the transmisson. Better pull the unit off and repair.
