JD 60 Governor
Joe
12-03-2001 13:24:32
When engine is running at steady no load speed should the tip of the governor arm touch the governor spring or should there always be a gap between them since the weights swing out and pull the same force on the governor arm as the tension in the spring?
buckeye al
12-03-2001 13:48:34
 Re: JD 60 Governor in reply to Joe, 12-03-2001 13:24:32
No gap means no response from the governor when engine is slowed for any reason.
