JD 50 flywheel
RonL
12-03-2001 12:39:42
The flywheel on my 50 gas does not have the timing marks stamped on the circumference. It has the LEFT HAND IMPULSE and LEFT HAND EXHAUST OPEN cast on the side of flywheel. Is this the correct flywheel?
joe
12-03-2001 14:32:09
 Re: JD 50 flywheel in reply to RonL, 12-03-2001 12:39:42
yes, that is the right flywheel.
RonL
12-04-2001 06:14:26
 Re: Re: JD 50 flywheel in reply to joe, 12-03-2001 14:32:09
I had this question because my other two 50s have timing marks on the circumference that allows you access through flywheel cover hole and this one does not. How are you supposed to use these marks to time.
