70 gas john deere
55 pickup
12-03-2001 09:30:28
I hope someone can help! My tractor was running fine.Then it began to run
only on the right cylinder. It has spark & compression but the spark plug looks dry (no fuel).It has a 2 barrel carb does the intake manifold have a runner for each cylinder? Thanks!!!
poorerbut
12-03-2001 10:14:38
 Re: 70 gas john deere in reply to 55 pickup, 12-03-2001 09:30:28
Looking for something simple, I would suspect a piece of dirt in the left barrel, maybe in the inside left nozzle robbing the fuel from it. There's a nozzle for each cylinder in the carb (I'm guessing you have a DLTX-82 or 85).You can pull the nozzle cap and nozzle after removing the bowl assembly and float assembly. Clooney may know of something else before pulling the carb off that you could try. Good luck . pb
