730 LP leaking propane
Ben.So.Tex
12-02-2001 16:08:28
I just bought a 730 LP It has been setting in a shed for about 6+ years,,maybe longer,, when I turn either knob on I can hear it leaking gas behind the dash, What could the problem be?..I think the rubber hose is cracked,,, I have not brought the tractor home yet, but plan on getting it home this weekend, This my first LP.I will have many question to ask about this tractor, so I will need all of yalls help, in getting them answered.Thank you
Kerry
12-03-2001 14:20:28
 Re: 730 LP leaking propane in reply to Ben.So.Tex, 12-02-2001 16:08:28
Just check it for leaks w/ soapy water like you would a tire if you can't find the leak. If it's leaking enough that you can hear it, I doubt it will be any problem to find.
Good luck, I've got a 50LP and we used to have a 720 LP, once you get the hang of it you'll love it.
Kerry
CLW
12-02-2001 18:19:38
Ben, There is a seal inside the valve. I got mine at a local propane dealer. There cheap and he new what they were. The dash has to be moved away from the tank to get to the repair area, but the repair is easy when you get room to work. Much like puting new washers on water faucets. Be sure and replace LP-lines while your in there. Your JD dealer can get them for you.
CLW
