70 Dist.
Roy
12-02-2001 13:06:55
Will a 70 LP dist. on a 70 gas help performance?
The Stranger
12-02-2001 14:18:05
 Re: 70 Dist. in reply to Roy, 12-02-2001 13:06:55
Not so you would notice. The reason for the 1/2 engine speed distributor on the 50, 60, and 70 LP-Gas tractors was to eliminate the possibility of igniting the incoming fuel-air mixture, since a regular distributor fired on both the power and exhaust strokes, while the 1/2 speed fired only on the power stroke. This distributor is useful on modified engines with increased valve overlap, but you would see little or no difference on a stock tractor.
