Bolts in john deere head
lynn
12-02-2001 08:00:49
putting back together unstyled a and was wondering if anybody has used bolts in place of studs for the head..the old studs need replacing..about all of the diesel engines use bolts.. i found some bolts out of an 870 case diesel that are 5 3/4 inches long and are grade 8 material..if using some kind of sealer on bolts to keep water from coming through would they work..lynn
The Stranger
12-03-2001 19:35:50
 Re: bolts in john deere head in reply to lynn, 12-02-2001 08:00:49
I wouldn't do it if I were you. It might work, but you just as easily might pull the threads out of the block, too. Using bolts isn't a good idea, and you'll be sorry if you do.
ryan
12-03-2001 07:55:07
I would think it would be okay to use bolts instead of studs. A local mechanic recommended that I use them on my manifold I would think it would be okay.
ryan
