****Matt, the good posts from my friends below have you started, hopefully, you may already have her figured out by now. To save myself a ton of time and since your question does get asked a lot, I will cut and paste my standard charging test to determine if your non charging is a gnerator or a Voltage Regulator problem. Like Steve pointed out, if its really a magneto as you claim, that has nothing to do with any charging or not and its not any load or even connected to the battery and charging system. Wico made a Model XB battery powered coil/disttributor that looks like their XH mags you know. *******A FEW QUESTIONS AND BASICS FIRST*********
First, it came originally as pos ground regardless if 6 or 12 volt, how is yours wired now????? ? If its wired negative gound (neg battery post frame grounded) and the ammeters wires were not already reversed, it would read bass ackwards. You say its not charging, is the ammeter working??? It should swing to discharge if you turn lights on tractor not running. Even with a good charging system, the battery has to be good and no shorts, or it can fail to charge plus run down when the tractor sits. Has a shop load tested it????? Is there electrolyte above all the plates and none appear gray or milky??? Have you tried a substitute known good battery and see if it takes and holds a charge??? If its got a 12 volt battery and its a good battery, I would stay at a 12 volt system, even if it was 6 originally. In so doing, its possible (but NOT ELECTRICALLY CORRECT AT ALL) to use the generator but a 12 volt Voltage Regulator and still operate and charge a 12 volt battery. Again, thats NOT engineering correct, but Ive done it before and not had any go bad yet. Im gonna have you check some preliminary things first to see if its charging regardless if the ammeter dont work,,,,, , and then have you check the generators and Voltage Regulators ground (They BOTH must be grounded to work),,,,, ,,,,,and then see if its polarized,,,,, ,,make sure the belt isnt just slipping,,,,, ,, and then troubleshoot if its a bad Generator or a bad Voltage Regulator. NOTE: The below is for a Generator equipped with a 3 or 4 wire Voltage Regulator, NOT a simple 2 wire cut out relay with a headlamp controlled generator field current regulation system. DO YOU HAVE A 3 OR 4 WIRE VOLTAGE REGULATOR, OR A 2 WIRE CUT OUT RELAY ONLY????? IF SO, LET ME KNOW AND I WILL SLIGHTLY MODIFY THE TROUBLESHOOTING PROCEDURE BELOW. Regardless what it had original, 6 or 12 volt, Voltage regulator or 2 wire cut out relay, it could have got changed over the years also, so let me know.
************PRELIMINARY TROUBLESHOOTING**********
A. THE VERY FIRST THING I would check is if BOTH the VR and gen are well grounded. You could run a wire from the batterys grounded post down to the gen and VR and attach it to their frame case ground and see if she charges??? A removal, clean and wire brush, and re attach all the mounts and bolts might cure a bad ground problem. B. Check and see if,,,,, SHES POLARIZED (momentarily flash jump connect a wire from the VR's BAT terminal over to its ARM terminal and you ought to get a spark) C. Check and see if the VR's BAT terminal shows hot battery voltage. D. Check and see if the belt is tight and not slick glazed looking. E. Even if you had no working ammeter or no voltmeter, with the lights on, you should be able to notice their brightness at idle, and they should glow noticeably brighter at WOT if the system is charging.
F. If you have a voltmeter, the battery should read approx 12.6 volts not running, but at WOT rise to around 13 to 14 if the system is charging, or approximately 1/2 those if a 6 volt system. G. A fully charged good batetry should indicate a specific gravity of 1.280 and all cells should have electrolyte above the cells and NOT appear gray or cloudy looking (bad cell). **********GENERATOR VERSUS VOLTAGE REGULATOR TROUBLESHOOTING*********************************
Below is my standard test I have posted often to tell if its a Generator or Voltage Regulator problem if shes not charging. However, you still have to have a good battery capable of taking a charge and all the wirign and grounds must be good and in place first. Some people print this and take it to the shop, so try it and let me know how you come out. 1) First, be sure the belt is good and tight, not glazed, and the generator has a good ground to the tractors frame and that the VR has a good ground. 2) There has to be hot full battery voltage present on the VR's BAT terminal so its output can get to and charge the battery. (Use a test lamp or voltmeter to insure that before you go on) The HOT path to get there, is from the battery itself or off the starter post, to and through the ammeter, then down to BAT on the VR. 3) Now, if the grounds are good and the VR's BAT terminal is hot, you can finally test the gen and VR to determine which or both are bad. With the tractor running, use a jumper wire and connect the F post out of the generator (smaller of the 2 gen posts) to the generators steel frame ground, and if the ammeter then shows charge, you either have a bad VR or a bad/broken wire connection between the generators F post and the F terminal on the VR. 4) If she still doesnt show charge, leave the F grounded, and then momentarily connect the BAT and ARM (or GEN) on the VR together to see if it shows charge. If she charges then, you have a bad cutout relay inside the VR. If it shows charge only if you connect the VR's BAT terminal direct down to the gens ARM post, the wire is bad (open) between the gens ARM post and the VR's ARM terminal. 5) With the F still grounded and the GEN or ARM on the VR connected to the BAT terminal and if the Gen and VR have good grounds and assuming the BAT terminal is connected to the battery via the ammeter and she still dont charge, its probably a bad generator, cuz you have essentially by passed any bad VR with the tests above. 6) You can also motor test the gen by removing its belt and all its wiring (protect all the wiring so it doesnt short out) and jump wiring the ungrounded bat terminal (i.e. - on a + ground system) to the generators ARM post (larger of 2) and the generator should turn like a motor. A source of such battery power could be the wire from the VR's BAT terminal, as it leads to the battery via the ammeter. If it runs when you do that, then ground out the generators F post and she should slow down slightly. If not, the gens field may be bad. If the gen turns when you apply battery voltage (from the BAT lead or elsewhere) and slows slightly if you ground out the F post, it should generate power fine. 7) For the generator to charge the battery, there has to be a connection between the BAT terminal on the VR to the battery (usually via the ammeter) and test that by using a test light or DC voltmeter and battery voltage should be present on that post ALL THE TIME. If the gens power doesnt reach the battery, it cant ever charge it, and the path is out the ARM post on the Gen, to the GEN or ARM terminal on the VR, through the VR's cut out relay, out to the BAT terminal on the VR, through the ammeter, then to the battery. 8) If she dont charge despite all that and the tests show the gen is bad and NOT the VR because you by passed BOTH the Field and Cutout Relay per the tests above, and the rest of the wiring is good and the gen and VR are grounded properly, heres a few gen troubleshooting tips: a) Many problems are the brush hold down spring assemblys are rusted and corroded so the brushes are not held down tight against the commutator. Use a wire brush and WD 40 and air etc to clean and free up the hold down spring assemblys so the brushes are held tightly down. If the brushes are not worn down too low and held down tight and she still wont charge, you may have an open field winding or a bad armature or a commutator problem. Post back if you want to repair the generator and I will further advise you. Post back your findinggs and any questions or e mail me at [email protected]. Maybe you just have a bad ground or a loose belt or she needs polarized??? So do the easy simple thigns first includign checking if the battery is good and the ammeter is working and wired correct and shes polarized. Good luck n God Bless ya Matt John T Nordhoff
