Update on 3020 Hydraulics
Albert
11-29-2001 20:27:04
I had posted a message about one month ago asking for help with a problem we were having with our tractor. The issue was the pump was making noise, the loader and all Hyd items were sluggish and sometimes would work fine and then shut down. Thanks for all the suggestions and we did find the problem. Turns out when the fitting on the bottom of Diff lock was broken off in the woods, there is a spring and a needle valve inside this area. The spring I saw but missed the two inch long needle valve and somehow it fell out. Due to this being missing, the system evidentely could not build up pressure and thus caused the pump to be deprived of oil pressure and work intermittently. Thanks
Albert
