4020 Shifting Problems
Elkhorn Denny
11-30-2003 09:43:38
I have an early model 4020. It does not want to go into 5th or 7th gear. It makes a spinning sound like it cant get all the way in gear. Does anyone know what the problem can be and if the tractor needs to be split to fix it? The tractor has 6,300 hours on it with a recent overhaul on the engine & clutch.
Paul
11-30-2003 16:23:40
 Re: 4020 Shifting Problems in reply to Elkhorn Denny, 11-30-2003 09:43:38
I just fixed a similar problem on a 30-10 and probably need to do the same on 25-10. the biggest problem was the shift fork was wore about 3/16" next the syncronizer clutches were shot as well as high speed hub and drum(the parts that mesh to shift)I could have just replaced shift fork but had to split tractor anyway so fixed it right. now a question do is it do this in all high gears (3rd,5th,7th and 8th)if it does it is the top shaft. if it is only 5thand 7th it could be on pinion shaft wich is kind of a pain.Paul
mike
11-30-2003 12:33:47
Get a manual and try to adjust the shif linkage. Also make sure the linkage in the dash is tight. If this does't do it,than it will have to be split to replace the synchronizers.
johndeere_doc
11-30-2003 15:01:53
 Re: Re: 4020 Shifting Problems in reply to mike, 11-30-2003 12:33:47
I would bet the linkage first, i would think if it was a syncronizer it would do the same in 3rd and 8th
just my 2 cents
johndeere_doc
11-30-2003 15:05:38
 Re: Re: Re: 4020 Shifting Problems in reply to johndeere_doc, 11-30-2003 15:01:53
After get thinking a little more it could even be the gears on the bottem shaft not locking to the shaft (b&c range)
