JD 1010
Jon,NH
11-28-2001 10:31:51
I'm in the process of breaking apart a 61'JD 1010 for parts.Someone asked me if it has power steering.Yes it does,It has some type of hyd unit mounted up under the hood in front of the radiator,that attaches to the steering post,oil lines run back under the hood to hyd unit under the steering wheel assembly.Is this set-up only made for nfe or can this be used on wfe tractor?Thanks..
jd man
11-29-2001 17:58:48
 Re: JD 1010 in reply to Jon,NH, 11-28-2001 10:31:51
it will need a bigger pump for the wide front.
