DLTX 18
Dan
11-28-2001 09:34:40
I have a 43 B I bought this fall. After cleaning the carb it started and run well (with the idle needle out 2 turns) but I was not able to try it under load because of other minor problems I'll fix next summer. Anyway, I removed and really cleaned the carb good this week and noticed it is a DLTX 18 instead of a 34. I'm not real concerned about it not being original but will it run right when the tractor is working? What tractor is the 18 supposed to go on? Thanks. Dan.
Todd
11-28-2001 09:45:03
 Re: DLTX 18 in reply to Dan, 11-28-2001 09:34:40
The dltx-18 is for an unstyled A tractor. Yes your tractor will run fine on it, although the idle and load needle settings will have to be adjusted closer so the tractor will run correctly. The carb has a bigger throat, different nozzle, etc. It WILL work, all of my B's have A carbs on them
