39B Steering Shaft
brian
11-28-2001 04:26:57
The opening in the support pedestal for the steering shaft in larger than the steer shaft (about 1/4"). Is there a bushing that goes in there? If not should I make a bushing?
Jerry S
11-29-2001 12:40:36
 Re: 39B Steering Shaft in reply to brian, 11-28-2001 04:26:57
I am no expert here but did read from a magazine that there was no bushing intended for that area however I have seen some people put some in there. Trouble is you need to turn the steering shaft down to get it in it from the pedestal to the steering wheel. Some guys have put a grease fitting on this to slow down the wear. Maybe the easiest would be to have someone build the shaft up a little if the wear was excessive. I usually just dab a little gun grease in it to keep it from rusting and making noise and let it go.
Guy
11-29-2001 09:39:10
I also wish someone could answer this question, I wondered the same thing about my 50. Doesn't look like there was anything there originally, but I can see where it is wearing and becoming slighty oval shaped. Would like to prevent any further wear if possible. If you wouldn't mind, let me know if you've gotten any advice on this. Thanks
