3020 diesel fuel pump change?
big john
11-28-2001 04:16:25
Any helpfull tips on replacing transfer pump, do you need to bleed system- How do you get at back fuel line, do you remove line from filter set on other side of tractor the pull pump out to remove back line? anyone change out? The new one does not have glass bowl?
JDJIM
11-28-2001 08:25:09
 Re: 3020 diesel fuel pump change? in reply to big john, 11-28-2001 04:16:25
The glass bowl type was replaced with the all metal type several years ago , all the fittings should fit at least mine did . It it a trick to get the lines off sometime , be carefull , take your time and don't strip any of the fittings . On your 90 degree ftgs. where the lines hook to the pump be carefull not to tighten them into the pump too tight you might crack the pump housing , happened to me . If it doesn't seem quite tight enough but one more turn would be too much remove the fitting and wrap some teflon tape on it , I do that on all fittings like that . The housings are just cast alluminum and aren't too strong . As for bleeding , loosen the line at the inj pump and use the hand primer till fuel fuel runs out at the pump without bubbles , tighten it up it should start .
