Wico X Mag Question
Jon
11-27-2001 11:41:31
The mag was completely cleaned, new points, rotor, condensor, coil, and cap were installed. I still don't have a very hot spark, what else can I do? I have had good luck up till now with mags. How far should the spark jump?
BooBoo
11-27-2001 17:44:17
 Re: Wico X Mag Question in reply to Jon, 11-27-2001 11:41:31
Jon, make sure your using steel plug wires and not resistor type wires, it will make a difference
Clooney
11-27-2001 12:02:20
Jon, depends on what you mean by "hot spark". Mags aren't noted for a real intense spark. The X is usually pretty good about a sufficient spark. About all you have left is to have the rotor re-magnetized, but that usually isn't a big problem on the X. Roberts Carb. can re-magnetize it for you at a very reasonable cost + shipping. Make sure all the rust is removed from the rotor & core & that all wires are in good shape with clean connections.
Jon
11-27-2001 12:10:28
 Re: Re: Wico X Mag Question in reply to Clooney, 11-27-2001 12:02:20
What I meant by HOT would be in reference to a pulling mag sold by robert's. I realize a stock mag can't live up to that, do you know what those mags contain versus a stock X mag? They are pretty expensive. Thanks for helping with the other question
Clooney
11-27-2001 13:00:02
 Re: Re: Re: Wico X Mag Question in reply to Jon, 11-27-2001 12:10:28
Jon, as far as I know a higher output rotor & a higher KV coil, & they only fire on the compression stroke (ie, every other stroke as opposed to every stroke on a stock mag). I am not a puller so can't attest to their effectiveness. It probably won't help a stock engine any though.
