JD 60 with 45 load will not lift
jack
11-26-2001 18:44:53
I have a john deere 60 with a 45 loader.
just started. Loader lifts very slowly.
and alos loader will drop withen 30 minutes.I have replaced the rear power trol gasket, no fix. Need help soon, snow is here.
DJ
11-27-2001 04:05:54
 Re: JD 60 with 45 load will not lift in reply to jack, 11-26-2001 18:44:53
My loader lifts very slowly and drops very slowly, also. I run the motor for a while and warm things up. It takes 10 minutes, but eventually starts working right.
DP
11-26-2001 21:46:52
Hello Jack, I am running a 45 loader on my 60 as well. Have used it for years with no problem till this summer. It raises alright, but in a half hour or so the loader would settle to the ground. Just the way it was acting, I went and got gaskets and the o-ring and backup ring for the lift piston. Removed the back end and everything in there. (O-ring on piston was getting thin in two spots). After putting the loader back on I found that the loader still dropped, but a little slower. I had one loader cylinder that seeped externaly a little, so I took it apart. The leather on the piston was like a rock, and broke. I replaced everything in that cylinder and am going to do the other this next weekend. I'm not sorry I went into the tractor, but probably could have got by without it. BTW, that leather in those cylinders is costly!
MIKE HANLEY
11-26-2001 21:27:54
Ouch! I have asimular problem with one of my 730D. When we had it on yhe round baler, it would open the door only part way very slowly and then stop. we returned the lever to neteral and then hit the lever again and the door would open and then stop again. It is at the J.D. dealer and they put a pressure guage at the remote outlet and it puts out the proper 1350 P.S.I. and then drops to 800 P.S.I. instead of holding the 1350 P.S.I. They checked out the relive valves in the box and they checked out O.K. They think it is a problem in a relive valve that is under the box. under the battery box. Now the bad news,,,,it is factory sealed and no longer avalable!!!!! they have our other 730D down there now and are going to switch reilve valves and if that will fix it then we have to find a valve off a junker to get them both working. I hope that is not your problem, but try a presser guage at your remotes and see if relive valve is working properly.
MIKE HANLEY
11-27-2001 12:36:18
 Re: Re: JD 60 with 45 load will not lift in reply to MIKE HANLEY, 11-26-2001 21:27:54
By testing with a pressure gage at the remote outlet with the loader hoses off, that will tell if the prouble is in the tractor or the o rings and seals in the loader.
