Wheel for '54 JD 60
Justin
11-26-2001 13:15:02
I have a '54 model 60 and the left rim has corroded due to a calcium chloride leak from the tire. I was wanting to know if you guys knew where I could find another one. Also, would a rim from another year of model 60 fit?
Thanks,
Justin
Bill from up North
11-27-2001 21:44:55
 Re: Wheel for '54 JD 60 in reply to Justin , 11-26-2001 13:15:02
My dad bought a JD 60 new in 55. You didn't say what model of JD 60 it is. Ours was a dolled up AR with wide fenders, a higher arched front axle, 30" rubber on the back - 16.9x30- and the engine ran a little faster than the AR. The dealer said it would replace the D we had. That was a laugh! Good thing Dad kept the 42D. The 60 was a good enough tractor but it wouldn't pull with the old D. Anyway- If you have the western model they are a standard double drop rim.
JD70Jim
11-26-2001 19:01:40
Justin:
Almost ANY place that sells tractor tires most likely would be able to supply a 38" double bevel rim in whatever width you require. My local Goodyear Tractor tire dealer sold me a new, 38" 14" wide double bevel rim for my 730---they had them in stock. I would bet that any reasonable agricultural tire seller has them.
Jim
Roy
11-26-2001 18:07:45
Try Wilson Farms Ph. 740-694-5071 got some really good prices
Roy
11-26-2001 18:07:23
Mike in Mo
11-26-2001 15:23:11
Justin Any 38" double bevel rim will fit your "60". just measure the width to get the size you want. All 60/70/620/630/720/730,IHC300/350/400/450/460/560 and later models with 38" tires would all be possible donors. Mike
Clooney
11-26-2001 14:56:57
Justin, Miller should have them.
