JD 70 gas Flywheel; tightening
Pete
11-25-2001 17:59:06
Need a little help! The 70 began knocking real bad recently, at first it only knocked when increasing RPM from idle, then grew worse. Now it knocks when ever the ckutch is NOT engaged, and when under load(slightly) when the clutch IS engaged. Since the main bearings were new just before I got her, and I replaced tha rod bearings, my 1st attack was the clutch. After all new clutch parts, even the dogs and toggles, the problem persists. The only other symptom is that the clutch keeps needing adjustment, so I assume it is a loose flywheel. Before springing for a taperlock flywheel, I am going to try to tighten it. Question; Do I need to secure the clutch side of the crank so that it doesn't move out when I drive the flywheel on? Any tips that could make it easier on me? Thanks Pete
-----Oh, I almost forgot, twice today I got a nasty grindong sound when applying the brakes...any connection to the above proble? Breaks are all new, and have been working fine.
Clooney
11-25-2001 18:53:51
 Re: JD 70 gas Flywheel; tightening in reply to Pete, 11-25-2001 17:59:06
Pete, the clutch needing to be adjusted all the time bothers me as that isn't usually a sign of a loose flywheel it is more a sign of a loose clutch driver or other clutch related problem. If the flywheel has moved on the crank splines it could cause the clutch to not completely dis-engage but shouldn't effect the actual adjustment. How much end play is in the crankshaft now, & does the flywheel show any signs of being loose? .....To answer your question, to push the flywheel on you will have to pull the clutch pulley cover & put a block of wood or jack between the crank & r/h tire to hold the crank to the flywheel side while pushing the flywheel on. The crank end play should be .005"-.010" which is just a very light thunk when the flywheel is moved in & out by hand. I don't know what your brake noise is but it could be rough drums, broken springs or a drum hitting the brake casting. Does it make the noise with both brakes?
