JD Model B: Stuck Gear
Dan
11-25-2001 16:33:45
I have been trying without success to pull the 4th and 6th gear from the sliding shaft. The tractor is a 201000+. After removing the cotter pin and nut from the shaft I tried using pullers up to a 5 ton rating and still can not get the gear to come off the shaft. I have also tried the old fashion way of pulling it by screwing in two 1/2 inch bolts but to no avail. I have also squirted PB Blaster and WD40 on the shaft and gear. Can anyone give me a hint?
Clooney
11-25-2001 16:52:37
 Re: JD Model B: Stuck Gear in reply to Dan, 11-25-2001 16:33:45
Dan, pulling that gear can test your tools. I have usually had to loosen the nut (do not remove) then use the biggest puller that will fit the gear, then tighten the puller as tight as you feel comfortable, then use an acetylene torch with a small fame & heat the gear near the hub all the way around the gear, then tighten the puller some more it will usually come off at that point. If you don't leave the nut on & the gear comes free the gear teeth can be damaged when the gear hits the floor.
fred-CT
11-25-2001 21:33:31
 Re: Re: JD Model B: Stuck Gear in reply to Clooney, 11-25-2001 16:52:37
Not tomention what it might do to your toes!!
