520 transmission
sam michel
11-24-2001 13:16:14
need help I put berrings in trans. put it back togather and it hangs up in sixth gear like it is trying to go into two gears at once. Havent been able to determine what the problem is. Any help would be looked upon kindly. thanks in advance sam
Clooney
11-25-2001 07:34:52
 Re: 520 transmission in reply to sam michel, 11-24-2001 13:16:14
Sam, can you define your problem a little farther. Does it just not shift or won't it move due to being 2 gears at once? If it is a shifting problem was it like that before you installed the bearings & did you modify or change the shifter springs or detents?
