46 B grounding
jdb
11-23-2001 19:52:01
i heard that my B should be positive ground, correct? well, mine is negative ground. if i switch it back what will i have to change around? will the starter run backwards? thanks,
joe
John T
11-24-2001 07:28:14
 Re: 46 B grounding in reply to jdb, 11-23-2001 19:52:01
It came from factory pos grnd. The starter will turn same direction regardless. I would re polarie the generator after you change battery and Im not sure if it has an ammeter how its wired it may or not be reversed. Good Luck Ol Jonh T in Indiana
