43B intake sweats ?
Ben So Tex
11-23-2001 18:54:54
Why dose the intake sweat on my JD B.pass the carb? I am working on a friend of mine tractor, and it sweats also. It too is a B. And is this harmful in anyway? Thanks
Clooney
11-25-2001 08:07:25
 Re: 43B intake sweats ? in reply to Ben So Tex, 11-23-2001 18:54:54
Ben, that is caused by the air restriction in the carb either at the throttle plate (low RPM) or venturi (high RPM) & is normal. It is the same effect as letting the air out of a tire, the escaping air rushing through a restriction causes the cooling of the valve stem & frost to form.
