Clutch Pulley Brake Pad (rivets)
Steve
11-29-2003 21:25:04
Does any one know the John Deere part number for the brass rivets for a model "D" clutch pulley brake pad,and foot brake lining, or is there some place else I could get them? Thanks to any one who can help!!!!
Clooney
11-30-2003 04:51:19
 Re: Clutch Pulley Brake Pad (rivets) in reply to Steve , 11-29-2003 21:25:04
Steve, you didn't tell us what year "D" you are working on..
~The early unstyled "D" [I think] uses a slightly different rivet than the later unstyled & styled.. If I remember correctly the later rivets [see Leon's post] will be slightly short in the early tractors.
~On the parking [foot] brake, the rivet is D1520R (10 ea).. That is for the later D's. my early parts book doesn't show that rivet broken down for some strange reason [probably as the band & lining was mounted in a different place serviced as a unit]..
[email protected]
JC
11-30-2003 06:21:09
 Re: Re: Clutch Pulley Brake Pad (rivets) in reply to Clooney , 11-30-2003 04:51:19
I took the brake band and belt pulley shoe to a local clutch shop and they cleaned, lined, and painted the parts for a very reasonable price. This was a late model styled D s/n 15x,xxx or 16x,xxx. You may want to make yours really original with the correct rivets and lining material. We just wanted ours to work.
BTW, they used 1/4 inch stock sounded very thin but ended up plenty thick enough. 5/16 would have been too thick for the brake band.
Regards,
JC
leon
11-30-2003 04:00:55
According to my JD parts CD, for a styled JD model D the rivet is a D1520R and the clutch pad is a D1932R. Then, according go the Deere parts web site, both parts are available from Deere and the D1520R rivets cost $0.21 each and the D1932R clutch pad subs to a R89780 and costs $11.75. LOL
STEVE JO
11-30-2003 06:11:52
 Re: Re: Clutch Pulley Brake Pad (rivets) in reply to leon, 11-30-2003 04:00:55
Sorry guys, I need them for a 1947 and also a 1930. What is the web site address for J D Parts? You mentioned according to your parts C D . Can you get a C D with parts list on it? Thanks for your information on your post!
leon
11-30-2003 20:27:25
 Re: Re: Re: Clutch Pulley Brake Pad (rivets) in reply to STEVE JO, 11-30-2003 06:11:52
You could start at "http://www.deere.com" or go directly to:>Link
0.jdparts.view.publicservlets.HomeUnsigned
The>Link CD I have is DB 1293. I got it at my Deere dealer, but have heard some rumblings that it may no longer be available. However, you should check with your dealer. It cost around $90, but contains the parts books for most two cylinder tractors.
