Correct Green Paint- Dupont Centari
Bryani I
11-22-2001 16:37:53
Thanks for all the help on the paint color questions I had. I decided to go with the Dupont Centari which is what I normally use anyway. Does anyone have the numbers for the green and yellow so I can get some mixed up? Thanks in advance.
Clooney
11-25-2001 09:41:52
 Re: Correct Green Paint- Dupont Centari in reply to Bryani I, 11-22-2001 16:37:53
Bryani I, I have used Centari in the past & found it to be easy to work with & holds it it's color well. The only color I have a number on is the yellow (I can't find the green can)& the number I have is for leaded paint (leadless paint will probably look different) [ 263A code:dt2612]. I am not sure you can use the color numbers that I have anyway as I had the paint store computer match the paint to my furnished samples then made a couple trips back for a slight tint change after a paint-out board was shot. Unfortunately my local paint store that I buy all my paint supplies from had my Dupont paint numbers in their computer but have since quit carrying Dupont products so deleted all the Dupont reference numbers. There was an article a while back in one of the John Deere magazines probably either Green Mag or 2-Cylinder (I can't remember which or even it was those two) that had a reference to the different paint numbers for some of the popular paint companies. I have found that computer matching with a paint-out for comparison gives me the closest match to the color I'm looking for. Once you get the color you like, keep a reference to that number & you will be able to match it later if you need to.
