John Deere 2550 Clutch ****Need Advice****
Gman
11-20-2001 19:17:31
Neighbor has a 2550 John Deere the slave cylinder was leaking,purchased a kit and installed it and bled but still the clutch doesn't release,I haven't worked on much of this newer tractors so I need some advice,I hate to split tractor and it be something simple. Clooney you got any ideas you seem to be pretty well up on this newer machinery. Thanks in advance Gman
ben
11-21-2001 17:28:38
 Re: John Deere 2550 Clutch ****Need Advice**** in reply to Gman, 11-20-2001 19:17:31
when repairng the slave cly i have found that the best way to bleed the cly is to run a small tube fron the bleed port on the slave cly. back to the clutch fluid resivior clear tube works the best as you can see the air beening removed. also where the tube from the resivor to the master has a low spot in it it will sometime trap air in it using this system save fluid and thoes special words!!!!
david val
11-21-2001 11:17:49
check the stroke of the rod of the slave cylinder while depressing the pedal. should be about 3/8".
if you have the stroke and no release,there is a problem with the clutch. if not ,more bleeding is required.
david
WTW
11-21-2001 09:02:27
Gman, The 2550 clutch is a common dry clutch like used on many other applications. The hydraulic master / slave system was used on the cab models. If the slave cylinder is actuating the clutch shaft on the side of the clutch housing then probably what may have happened is before the repair of this hydraulic actuating system the clutch was not being fully disengaged causing slipping and heating during clutching functions causing damage to the clutch unit. If the clutch pedal feels normal and the slave cylinder is reacting to pedal movement, this is what I would expect happened. Tractor with this type of hydraulic actuator require no clutch pedal free travel adjustment. So if its working there is nothing you can do but take a further look inside. Good Luck, Dave W.
