JD A Rockshaft
Bob
11-19-2001 19:21:14
The rockshaft on my early styled JD A won`t go up under its own power. The PTO is engaged and it has fluid. Any sugestions on what could be wrong?
fred-ct
11-19-2001 19:46:21
 Re: JD A Rockshaft in reply to Bob, 11-19-2001 19:21:14
Bob, you did not say if you had a "power lift" or, "Power-trol". I had almost the same problem with my "Power-trol" - it went up but not down. I believe that you need to adjust the metering screw on the left side of the Power-trol. (Looks like a long 5/8" bolt sticking out about 1.5"). This is actually a cap o the screw underneith. Screw in to increase the lift speed and out to decrease.
Another possibility is that the leather i the piston is bad - try the screw first - it sounds a lot easier.
Good luck, FSB
