Pete
11-19-2001 19:10:06
Re: JD 70 clutch and pulley removal in reply to Andrus Burr, 11-19-2001 18:13:30
Andrus, After removing all the discs, I assume you used jack studs to remove the fixed disc? Then you have to remove the pulley shield and the complete first reduction gear cover. One you have unbolted the whole cover, the entire pulley, shaft, sleeve, and cover will come off. If at this point you only went in this far so that you can replace the bearing, then you are lucky, simply use a punch to drive the bearing and seals out from the back and flip it over and replace it. If like we did, you are in this far to replace the dogs and toggles, then strap in, your in for some fun! If this is the case, find a large three jaw puller, a strong impact wrench, a set of torches, and some PB Blaster. Nothing else can be removed from the back untill the drive gear is pulled off, then the reduction gear cover, operating sleev, dogs, toggles and adjusting bolts can be removed and replaced. Once ya get all that stuff replaced, find a BIG press, I repeat, BIG, and press the drive gear back on. Good luck, an IT manual is still available, and it does the usual 1/2 assed job of instructing you on this. Clooney and the biys here were much more helpful to me than the IT though. Pete
