Clooney ?? on adding aux valve for 60
Chris
10-15-2003 09:57:38
Clooney I am going to add a aux. valve. Weve been here before. You suggested brazing the fittings on the steel tubing. What fittings have you been using and what kind of braze. Have you used silver solder or another type. Thanks Chris
Clooney
10-15-2003 16:08:44
 Re: Clooney ?? on adding aux valve for 60 in reply to Chris , 10-15-2003 09:57:38
Chris, I usually make [machine] a saddle that sits on the line then drill & tap it to the outlet thread I plan on using, then silver solder that to the line. ~If you don't have access to a machine shop you can probably make the fittings you need from a piece of steel pipe, or even an old nut that has the center drilled & threaded to the correct fitting size then use a file to fit it to the steel line.
~The suction side isn't real important but the pressure side should have a pretty good fit & overlap so you get a good silver solder or braze joint. Brazing rod will work good but I like the silver solder a little better as it takes a little less heat & flows to flux a little better..
