JD Super G 70
Dave W
11-19-2001 10:12:37
I'm looking for some info on a John Derre Super G 70. Horse power,Weight,? bottom plow ect.. Any replys greatly appreciated. Dave
JD70Jim
11-19-2001 13:54:27
 Re: JD Super G 70 in reply to Dave W, 11-19-2001 10:12:37
Super G 70? I have heard of the "70" being refered to as a "Super" G but John Deere did not actually ever call the "70" that. The "70" on the other hand, is the direct replacement for the "G" tractor. It was introduced in 1953, a year after the 50 and 60. It is aproximately a 50 hp tractor, was available in "Row Crop", "Standard" and "High Crop" chassis configurations and you could buy one with a choice of Distillate or Gasoline engines in 1953, LP gas in 1954, and diesel in the 1955 model year. Live power take off (Lpto), live hydraulics, power steering, a choice of up to five front ends---single front wheel, conventional dual wheel narrow, Roll-o-matic narrow, a fixed 38" wide front or an adjustable wide front end--- were all available for the row crop tractor. It weighed 6035 lbs, had a 379.5 cid gas, 413 cid distillate, or 376 cid diesel engine. The rated rpm of the spark ignition engines was 975, diesels ran at 1125rpm. Serial nr 7043757 was the last one built.
Dave W
11-20-2001 22:27:54
 Re: Re: JD Super G 70 in reply to JD70Jim, 11-19-2001 13:54:27
Thanks for the info. I am researching this for a friend and seem to received some incorrect info. Thanks again.
I'm lost.....??? nt
11-19-2001 12:14:38
Interesting model.
Jason D. Wahl
11-19-2001 17:49:55
 Re: Re: JD Super G 70 in reply to I'm lost.....??? nt, 11-19-2001 12:14:38
Simply put there is no 'JD Super G 70'. It is either a 'G' or a 70.
Dave W
11-20-2001 22:15:42
 Re: Re: Re: JD Super G 70 in reply to Jason D. Wahl, 11-19-2001 17:49:55
Thanks for the correction. I personally don't know diddly about the old JD's. Researching this for someone else. I don't mean to make anyone upset, but thought this the place find the truth.
