3020 hyd not working good on loader
John
11-18-2001 11:21:51
I have a 64 3020 with a 35 jd loader the loader moves up fine but wont go down very good. going down the hyd pump loads the engine harder and takes a long time to lower it works much faster if i move the bucket up and down at the same time. the bucket works good up and down. my loader is plumbed in to the line by the brakes peddles and returned in to the filter cover and has a hyd control for the loader does any one have a clue?? all the hyd fluid was changed and filter replaced. when you stop going down loader comes up about 6 in. after you release control lever. is it the control valve, a bad hose?? thanks for any help.
Lee
11-18-2001 20:39:43
 Re: 3020 hyd not working good on loader in reply to John , 11-18-2001 11:21:51
I have seen a faulty hose act like a check valve. What happens is there's a loose piece of hose on the inside, when the oil is going in one direction the piece is fine, but when the oil travels in the other direction the loose piece of material falls down like a flap and resticts the flow of oil. The bad hose will more that likely be the one for raising the loader from the valve to where it splits for the cylinders. Hope this helps or gives somewhere to look. Good Luck.
Dan
11-18-2001 19:15:22
Do you have a closed center valve on it? The 3020 has a closed center system whereas a lot of the older tractors the #35 was used on were open center.
I have a JD 430 with a #35 loader. ON the valve there is a line that returns to the rear end in addition to the regular ones. It comes out the side of the valve. They tell me this was to make the loader come down faster, kind of a rapid bleedovv system
John
11-20-2001 16:56:44
 Re: Re: 3020 hyd not working good on loader in reply to Dan, 11-18-2001 19:15:22
how do you know if you have a open center or closed center valve? the loader really binds when trying to lower it I will check hoses and coupling this weekend. thanks
John M
11-18-2001 13:14:23
Could be restriction of return couplers at filter hsg, replace male & female ends, or plumb return hose directly to filter cover.(where female coupler screwed in)
