3020 JD Gas Distributor
DHunter
11-17-2001 09:08:34
I have a 3020 gas S/N 134676R and the distributor housing is broken completely off just below the lugs that receive the cap retainer screws. The local John Deere dealer tells me the the distributor is no longer available. Can anyone give me information as to where I might find a complete distributor? I know it's made by Delco but haven't found a Delco number on it.
john2510-3020
11-17-2001 11:30:36
 Re: 3020 JD Gas Distributor in reply to DHunter, 11-17-2001 09:08:34
yes teh distributors are still available, or around here anyway(Mo)but instead of spending a lot of money i just went and had my rebuilt in Kansas for around $100....but mine wasnt broke just needed rebuilt. i dont know what to tell you other then that...oh also how did you manage to break it off??? just wounderin'.
john
DHunter
11-17-2001 14:13:49
 Re: Re: 3020 JD Gas Distributor in reply to john2510-3020, 11-17-2001 11:30:36
Well John, when I posted I didn't know why it had broken. Then I went back and took a better look at it and, lo and behold, the advance weights had rubbed it clean into from the inside. Don't know enough about the way it's supposed to be made to know why it happened but suspect someone tinkered with it before I bought the tractor and didn't put it back together right. If you know of someone in your neck of the woods or anywhere else who's got one for sale please let me know.
john2510-3020
11-17-2001 18:09:26
 Re: Re: Re: 3020 JD Gas Distributor in reply to DHunter, 11-17-2001 14:13:49
DHunter you might check with 2 cylinders plus down here in Mo. i dont have there card right now with the address or phone# but if you would like me to look for it and give it to you tomorrow i can.what year is your tractor, if you dont mind me asking, is it powershift or syncrorange? also you might check with Cooks Tractor up in Clinton heres there number and address 660-885-2287 there on Highway 7 in Clinton Mo. where are you located by the way? If you in Ill. then you might try them up ther at 618-526-4244 or you might try Hanson tractor parts in Chanute Kansas ph.# is 800-662-2875 or another place in Ill.is Wrights Auto and Tractor parts 800-398-3448 or the evenings is 217-222-2792. this may give you some places to try.
john
DHunter
11-18-2001 15:52:17
 Re: Re: Re: Re: 3020 JD Gas Distributor in reply to john2510-3020, 11-17-2001 18:09:26
John, I'm located in Waggaman, Louisiana just on the outskirts of New Orleans. I believe the tractor was built in 1973+/- and it is a synco-range. I posted the serial number above. There was just enough metal left so that I could put the housing back together exactly and secure it with clamps. Now I am in the process of repairing it inside and outside with JB Weld. Looks like it's going to be ok. Thanks for all the contacts but I may not need them. I have determined that it is a Delco Remy and has the following numbers on it: 1112648 9F26.
