Air Conditioning conversion on 4050
Junkman
11-16-2001 18:17:39
I was wondering if anyone of you guys have had any A/C experience. How hard is it to convert a 4050 to the new r-134A refrigerant? The dealer wants $2000 to do it and I know I can do it myself, but any info you could give would be greatly appreciated. Thanks in advance.
Junkman
Carl R
11-17-2001 19:38:44
 Re: Air Conditioning conversion on 4050 in reply to Junkman, 11-16-2001 18:17:39
On some of the earlier 50 series tractors there was a timer relay under the roof. If there are two lights beside the thermostat in the cab, you still have the timer relay. This timer relay is OK when it works right, but a lot of them don't. Deere makes a kit consisting of two pressure switches and a new hose which eliminates this problem. Ask for part # RE24456, which runs around $206. Follow the enclosed instructions exactly and you will have no trouble at all.
I prefer to change systems over ONLY if the compressor (R12) fails, which does not happen all that often with the Nipendenso compressor. When I change a system over, I change compressor, receiver/dryer, and expansion valve. I also flush the system with a brake/parts cleaner. I have not had ONE come back with problems if I am allowed to switch things over in this manner. $2000 seems a little steep, labor rate about $65/hr?
Russ
11-17-2001 17:41:51
What we do in the shop is evacuate the R12 into our reclaimer. Take compressor off and drain all the oil out. Install 11oz of ester 100 oil, install new rec/drier, remove shrader valves from the A/C lines( if you have high press switch only remove lo side valve) and install R 134a coupler. Install 80% of what R 12 charge is ( ex.4lb of R12 and you will need 3.6 lb of 134a. Vacuum system down and charge A/C system.$20.00 for freon and %20.00 for ester 100 oil and whatever the rec/ drier is is all you have for expense.
I recommend replacing rec/drier since the 2 oils and freons do not mix and this will eliminatemass contamination of freon. Chances the rec/drier is old and dirty any how.
Good luck
signman
11-17-2001 08:57:35
Do you want to know the EPA way. Or the way that it is done on the farm. Kmart Walmart and the local Auto discount stores have a kit for about $50. That's right $50 that will adapt and refill your current system with R134. it is your choice on how you dispose of the R12 in your system as far Vacuun and all. We have had a 4230 that has never had a good AC. Where my 4430 has an after market 134 system that will freeze you out.
I took one of these kits and filled the original 4230 AC system with the provided oil and refrigerant along with a can of O-ring conditioner and sealant. For 2 years we have enjoyed the first cold air ever out of that system.
I have since had used car dealers say they have been doing this for years.
Plant Doctor
11-17-2001 05:48:18
Junkman: Before you go to all the trouble of converting to the 134a, go to this website and read about ES12a refrigerant. (http://www.autocool-refrigerants.com/product.htm)The ES12a is a much easier conversion, safe and much more efficient than the 134a. I haven't converted any of my tractors yet, but I have done two pickups and this stuff is great. After reading about it post back and tell us what you think. Good luck.
john nelson
11-16-2001 21:57:35
johns right, the rules are really specific, just remember its the same syestem as your car or truck, ask the guy down at napa, he will probably have the answer
john
G Taylor
11-16-2001 19:32:30
New o-rings everywhere to hold the smaller R-134a molecules in. Sometimes a higher pressure cutout switch is required at the compressor & a smaller orfice. Thee will be some loss of capacity compared with R-12. Unless you have a vacuum pump & gauge set don't try this at home.
John M
11-16-2001 18:59:40
I forgot, you`ll need Hi&Low side adaptor fittings at chg\press ports. Also, whats left of R12 in original system, must be reclaimed. (thought I`d better cover my !@#.
John M
11-16-2001 18:47:53
No Big Deal. We drain oil from compressor, add 8oz Ester 100 oil, remove filter\dryer,blow out lines for heckofit, install new dryer, Vacumpump system, & charge.(48-54oz) This is for changeover only, not all end up to be this simple.
