JD 60 Head Gasket
Gary
11-16-2001 07:40:56
The head gasket I removed was of a soft material with metal inserts so the copper or aluminum spray would be appropriate to use. However, the new one I got from JD is metal on both sides. What if anything should be applied to this gasket as a sealant?
Jason D. Wahl
11-19-2001 18:50:14
 Re: JD 60 Head Gasket in reply to Gary, 11-16-2001 07:40:56
Mike's idea is fine. Just make sure you re-tighten the head nuts once you get it good and hot once. Don't skip the ones behind the rocker assembly! Jason
Mike Aylward
11-16-2001 18:11:51
Gary, I normally don't use anything on head gaskets but on a late A or 60 tractor, which are prone to seep, I use some #3 Permatex on the outside vertical rails of the gasket on both sides of the gasket. Torque the head in 10 lb. increments to 150 lbs., run the tractor and check it again. I have done this for several years and have had good success with it. Hope this helps. Mike
joe
11-16-2001 16:00:59
no, you dont need anything.
