5020 hard starting
jack
11-15-2001 09:32:25
I have a 12 volt starter on 5020 John Deere. Experiencing hard starting. Has to turn over a long time before starts. Moreso when weather gets colder. I don't like the idea of using starter fluid all the time. Suggestions ???? Are there high speed starters available? Will that help ?
jack
Bob W
11-17-2001 19:38:58
 Re: 5020 hard starting in reply to jack, 11-15-2001 09:32:25
Install a manual destroke screw in the hydraulic pump if it's not already there or start using it if it is. The screw is available from your Deere dealer for less than $20. They can make a real difference.
Joe
11-16-2001 20:05:53
Started could be dragging check resistance with multimeter, make sure resistance is within specifications. How old is your battery? Or you might not have enough cca's (cold cranking amps),too small of battery. Does the starter turn fast enough. Check charging system to make sure the battery is being charged adequately. Check battery cables for resistance or corrosion. Make sure all hydraulics and PTO are not engaged.
G Taylor
11-16-2001 19:52:57
What rpm does it crank over at. Use a tach & crank without fuel. Could be starter, battery, battery cables, injectors/compression as previously mentioned.Even just low charging voltage. A good condition typical 24v system whips the otherwise identical engine over faster than the typical 12v system in the same condition. Has this tractor been converted? What year/serial number is it?
duke
11-16-2001 16:13:02
Sounds like low compression to me. Time for an overhaul
ET
11-15-2001 12:48:23
Have you checked injection pump timing. When were the injector last serviced? A poor spray pattern
will make hard starting. If your 3 point hitch
settles pull the leaver back so the hydralic pump isn't pumping oil when you are cranking it to start.
