4010 carb to rich
lhb
11-15-2001 05:17:59
i have a 1963 4010 that has a carb off a combine that runs to rich. is there any way of leaning this down?
John M
11-16-2001 17:52:16
 Re: 4010 carb to rich in reply to lhb, 11-15-2001 05:17:59
I was waiting for some one to answer your post so we could both get an answer. I have run into this before, where the marvel carb(allum./potmetal)has been replaced by Zenith from comb. I`ve tried to re-jet, but didn`t work&have wondered if the venturi size is part of problem. The local Deere dealer says OEM carb is oboslete but has access from another source.$$$(would love to know who that is) We have gottenby with changing ign to solid state & using hot plugs with a gap of .40+ I should add this is concerning 3010`s & several IH 454 thru 674.
G Taylor
11-17-2001 03:25:05
 Re: Re: 4010 carb to rich in reply to John M, 11-16-2001 17:52:16
On some occassions the choke may appear wide open but is actually partly closed. The cable is known for sticking.The only way to be certain is to look into the carb. The fuel bowl level maybe high due to needle/seat/float problems. These tractors need the manifold heat turned on a well to ensure fuel vapourization.Liquid fuel doesn't burn.
