310 JD backhoe stuck in low range
Paul C. Smith
11-13-2001 17:13:22
My backhoe is frozen in low range. The left shifter wont move to the park or high range position.My guess is the shifting rod is rusted in the transmission bushing.How do I find the problem.
Brokenwrench
11-14-2001 16:09:27
 Re: 310 JD backhoe stuck in low range in reply to Paul C. Smith, 11-13-2001 17:13:22
You may find that the shift lever has jumped past the shifter rail. Remove the shift boot the snap ring and pull the lever out, the shifter rails are visible thru the hole. Use a screwdriver and line up both gates, this should be neutral. Start the tractor and check if its out of gear if so reassemble lever and youre good to go. Hope this helps.
Paul C. Smith
11-15-2001 12:43:02
 Re: Re: 310 JD backhoe stuck in low range in reply to Brokenwrench, 11-14-2001 16:09:27
Many thanks Brokenwrench. It took only a few minutes to fix my problem.You were exactly right.Thanks again and God bless.
