Batteries in series
Ted
11-13-2001 17:09:51
When charging 4-6 volts in series, do you set the charger on 6 volt or 12 volts? I know that the two 6's are conected but don't know what to set charger at. I have negative grounds with positive and negative conecting the two 6's. Thanks Ted.
Clooney
11-14-2001 07:46:21
 Re: Batteries in series in reply to Ted, 11-13-2001 17:09:51
Ted, you didn't say if the truck system is a 12 volt or 24 volt system (2 sixes on each side in series & each side in parallel=12 volt) Or all 4 in series=24 volt. In any case if you try to charge the batteries in series & you have one bad battery you will get a poor or no charge in the full system. If you have the time, & to be totally safe if not knowing the battery lay-out just charge each battery separately as a 6 volt battery.
John T
11-13-2001 20:09:23
Ted, I assume you have a 12 volt charger ??? So I would connect it across two of the sixes in series (12 volts) and charge them, and then charge the other two batteries same way. If you ahd a 24 volt charger, you could do all at once. Polarity is neg to the last (not the jumpered mid terminals) outer neg terminal and positive to the first pos term. Good luck Ol John T in Indiana
a gebhart
11-13-2001 17:31:10
as long as positive to positive you have 6 volts
Ted
11-13-2001 18:19:43
 Re: Re: Batteries in series in reply to a gebhart, 11-13-2001 17:31:10
a gebhart, i have positive to negative on four six volts, two on each side of truck, Mack farm truck. Neg. ground. Ted
Gord
11-13-2001 17:29:01
Hi Ted, your post is a little missleading but I gather you have TWO six volters and not four, correct? If you only have two and they are connected neg. of one to pos. of the other then you should have a neg. and pos. loose lead from the two, then you put the charger neg to battery neg and charger pos to battery pos and set charger to twelve volts, Gord.
