47 A brakes
DJ
11-13-2001 16:18:38
How do I adjust the brakes on this tractor? The pedals go all the way down and the tractor won't stop.
Tom in Mo.
11-13-2001 17:39:12
 Re: 47 A brakes in reply to DJ, 11-13-2001 16:18:38
The factory service, parts, and operators manuals are a must for the collector or the hobbyist of the old cast iron. If you get this information, you will wonder how you ever did without.
The Deere factory manuals are the best I have seen with Ford a close second.
chris in WI
11-13-2001 17:26:02
there is a small square pin that sticks out of the back of the brake drum (on the pedal side of the drum) this is you're brake adjustment. Turning it clockwise will tighten the brakes up for you. If you can't turn this adjuster (which you probably won't be able to do) you'll probably have to take the brakes off (easy, two bolts to remove, then wiggle and pull). Then you can inspect the brake pads, which you should do anyway, and free up the adjuster.
And keep in mind: even when it's properly luibrcates and in good shape, the adjuster is hard to turn.
Hope this helps.
chris
