JD G Engine Rebuild
Todd Harris
11-13-2001 15:43:16
I am having trouble locating main bearings and rod bearings, 10 thousandeths under. The bearing housing parts nos. are #F752R and #F770R. Does anybody know if JD 70 bearings are the same as a G's? Thanks.
Deere Jon 2000
11-14-2001 06:25:54
 Re: JD G Engine Rebuild in reply to Todd Harris, 11-13-2001 15:43:16
I can't help you with the availablity of parts, but I don't think 70 main bearings are the same size. In the late 1960s we had to replace the pulley side main on our "G" and the JD dealer sold us the main for a "60". We had to have the bearing machined to fit. The problem with the flywheel side main is that the starter mount is part of the main, and the "G"s starter is on top of the crankcaes and the "60"s is at the bottom.
Gman413
11-14-2001 23:36:32
 Re: Re: JD G Engine Rebuild in reply to Deere Jon 2000, 11-14-2001 06:25:54
Todd I think a late "G" and a 70 share the same sleeve type main bearing. If you got the split bearing with shims why not adjust the bearing with the shims unless you have crank or bearing damage, Rod bearings should be available thru John Deere or a good machine shop.Gman
