JD 50 Power vs. Farmall A-C
Nate in IL
11-29-2003 09:56:42
What was the power rating of the JD 50? What Farmall and A-C is it comparable to?
Nate
Steve - IN
11-30-2003 09:41:15
 Re: JD 50 Power vs. Farmall A-C in reply to Nate in IL, 11-29-2003 09:56:42
Nate,
The contemporary Farmall that's closest to a 50 is a Super H. Both introduced in '53. The SH was rated at 30 drawbar and 33 PTO HP. The Farmall H had about the same production dates as the JD B. You can probably argue all day about which has the most power - but the simple math says that any comparable HP low revving JD 2 cylinder will have a lot more torque than any higher revving 4 banger like a Farmall or AC. The WD A-C might be a closer comparison to the 50, I think the HP rating of a WD45 make it closer to a 60.
old
11-29-2003 10:14:31
A JD-50 is about 30 HP Allis WC about the same and a Farmall H is 26 HPand the M is 34 HP. All of that is by the Neb. test
