Carb cleaner
Dan
11-13-2001 07:06:46
My DLTX 34 carb runs good but I would like to strip the old paint off. I've used a lye & water mix on other parts with good results. I'm thinking it should clean out any varnish in there also but could it hurt anything or would a carb soak be a better idea?
Thanks. Dan.
Phil
11-14-2001 13:33:28
 Re: Carb cleaner in reply to Dan, 11-13-2001 07:06:46
Carb cleaner won't bother the carb at all....I have always preferred to use Brakeleen when working with them on final cleaning/re-assembly, as it dries very fast & doesn't leave a residue like carb cleaner can. Be careful to were rubber gloves, as it dries your skin as well. To remove the paint & really spiff it up, if you know an engine builder with an abrasive cabinet (use walnut shells or absorbant beads), you can make them look like new with a coat of clear or green.
joe
11-13-2001 18:30:38
carb cleaner wont hurt it. i did it my self.
