How do I remove a brake drum
Michael
11-12-2001 19:13:39
Model A about 1950 has been sitting for 20+ years, the brakes appear to be stuck on. How can I free them up?
Russ
11-12-2001 22:00:40
 Re: How do I remove a brake drum in reply to Michael, 11-12-2001 19:13:39
Most likely I would start with foot pedal pivot, try and loosen it up with some wd-40 and lightly tape back and forth. You will probably end up removing the whole assembly (3 bolts) and do a complete dis-assembly. The adjustors are probably stuck anyway, and you need to inspect the linings, return springs, etc.It is not difficult work just time consuming. Be sure and put new gaskets on when you re-install the brake assembly. Russ
donwisc
11-13-2001 15:25:41
 Re: Re: How do I remove a brake drum in reply to Russ, 11-12-2001 22:00:40
I agree with the previous post that you pull the assy off and disasemble. Make sure every pin is loose, polished and lubricated before putting back together. Once you see how simple the mechanism is and the results youll look forward to taking the next one apart. Don
