JD 401(2020)Diesel
drain water from fuel filter glass bowl
Frank
11-12-2001 12:53:41
How can i drain this without creating an air pocket. i don't want to have to bleed the injectors as well.
jonathan
11-12-2001 14:58:08
 Re: JD 401(2020)Diesel - drain water from fuel filter glass bowl in reply to Frank, 11-12-2001 12:53:41
..I'm assuming you have the older round filter with the glass bowl on the bottom...the drain plug on the bottom of the filter retaining bolt should drain the water out...usually the passage in the bolt is plugged with debris and rust...then after its drained, loosen the bleed screw on top of the filter housing and give the lever on the transfer pump a few pumps...usually the passage in the top bleed screw is aimed right at you and you get a nice spray of fuel on yourself. !!!Then close the bleed screw and you should be good to go...
