Jd 60 shaking/vibration/knock
JD60
11-11-2001 15:48:51
Thanks to all those responding!
Anyone else want to take a shot at it???
Thanks!!!!
Roy
11-12-2001 16:18:47
 Re: jd 60 shaking/vibration/knock in reply to JD60, 11-11-2001 15:48:51
Check the flywheel!
Charles
11-12-2001 06:06:28
My "50" has a vibration too. The clutch disk is properly lined up with the marks but the old pulley bearing must have seized at some point (or was just never greased) and wore a deep groove around the crank snout. (There is no inner race, the rollers ride directly on the crank).
Even with a new bearing there is enough eccentric motion that it vibrates some. Crank has to be removed to fix this properly...
Ralph
11-11-2001 16:17:36
JD60, I don't see how this could be the problem in your case but on a 60 it is possible to put the driving disc in the clutch on out of balance. There is a v mark on the crank and one on the disc. If the two v marks are not lined up, the 60 will shake.
JD60
11-11-2001 19:09:25
 Re: Re: jd 60 shaking/vibration/knock in reply to Ralph, 11-11-2001 16:17:36
Ralph, Thanks for the response. The flywheel was loose when I bought it, the owner tightened it.
Now after 1.5 yrs. of occasional use the tractor gained its shaking/vibration stuff again. Only this time a knock has showed up near in the clutch housing. The clutch facings were replaced, along with a new fork, crank bearing.
I haven't been able to convince the mechnic to look at the flywheel. I'm looking at all ideas, can't keep shoving money at it.
DP
11-11-2001 20:15:49
 Re: Re: Re: jd 60 shaking/vibration/knock in reply to JD60, 11-11-2001 19:09:25
jd60, all the symptoms you talk about point to the flywheel being loose. The noise will sound like its from the pulley side. Don't run it very much that way, or you'll be putting a crankshaft in it. Good luck, Don
