John Deere Distrutor
Travis
11-08-2001 09:12:15
I have a 47 JD "G" with the wico mag on it...I pull this tractor. I have M&W pistons in it. I was wondering if I could put a distributor on it from the new G or another tractor..about how much would it cost and is it worth it....also is there any other options that I can do instead to do the same..thanks
Clooney
11-09-2001 03:44:30
 Re: John Deere Distrutor in reply to Travis, 11-08-2001 09:12:15
Travis, if you want to remove the battey & generator for a weight saving, Roberts Carb... (Phone: (712) 262-5311)
sells a very good mag for pullers. A Super Hot competition magneto. The magneto comes with a hot coil & a schedule 8 magnet rotor. The magneto only fires on the power stroke & the price is $375.00.
John T
11-08-2001 17:33:59
Travis, if youre going to get into serious pulling and maybe running very high compression or exotic fuels, I definitely say use at least the delco distributor and coil which, as they said below, bolts right in. That mag has no extra energy to spare but is fine for what it was designed for i.e., low compression and regular old fuel. An electronic ignition like Gennesse or others make delivers way more spark energy (volts time amps) across a wider plug gap at higher amperage with a good fat hot blue spark, but unless your compression is way high and your using hot fuels, the delco will probably do fine. As Clooney and I have mentioned and agree on many times, the so called HIGH VOLTAGE COILS which you may be tempted to use in lieu of the stock delco type, will fire at the same volatge which is dependant on the plug gap, the medium in which it fires, and the overall internal resistance. Start with the delco and see how she performs. Good Luck Ol John T in Indiana
Chuck
11-08-2001 11:56:46
from what I understand, folks are putting the delco distributors used on 50/60/70 and then adding electronic ignition.
JDGnut
11-08-2001 14:15:24
 Re: Re: John Deere Distrutor in reply to Chuck, 11-08-2001 11:56:46
Yup.. bolts right on. Or if U can find a LP dist, that will work a little better, but looks a little funny. If fires half as many times as the regular dist... basically it fires only at the top of the compression stroke. JDGnut
