I posted the following message to the AC discussion forum, and am just looking for any opinions anyone may have.....the fact it's an AC really doesn't have much bearing on this question....it's more of a generic engine question.... (but for the record, I'm a JD man and have received some very good assistance from this forum). I've already got 2 strikes against me....I don't claim to be much of a mechanic, and I've never touched AC's before....but I like to try anyway.
This tractor supposedly ran OK when it they parked it 10 years ago...and it did have antifreeze in it the entire time. As of this morning, it didn't have much/any compression on 5 of the 6 cylinders. After pulling the valve cover, we could see that the intake valve on those 5 cylinders was sticking down, and then veeeerrrrry slowly rising back up. The push rods on two cylinders we not even under the tappets any more. After lots of WD40 and prying back up on the valve springs and resetting the push rods/tappets several times, we appeared to be in business as all the valves now appear to be working quite smoothly....until I went around and did a quick compression test with my finger over the spark plug holes. Two of the cylinders still have no compression. Looking through the spark plug hole, the pistons DO appear to be going up & down. I'm just looking for your best guesses on the cause, based on the history of it sitting. I'm just not sure what things would usually cause low compression vs. no compression...and this sure appears to be NO compression to me. If the rings were just worn, I would guess low compression. The only other things I can think of are bad head gasket, cracked head, bad valves and/or seats, cracked block, bad/broken pistons. Could the rings stick 'in', such that they aren't against the cylinder walls? If so, is there a recommended approach to freeing them? Diesel fuel or anything else dumped into the cylinder? I'm really not looking forward to tearing it down, but it looks like that's where we're heading. Thanks for ANY input.
