Head bolts on 4020
Sam Dean
11-07-2001 13:35:24
Replacing head gasket had head resurfaced should i replace head bolts?
Steve II
11-07-2001 15:07:14
 Re: Head bolts on 4020 in reply to Sam Dean, 11-07-2001 13:35:24
I dont think really need to.... I just worked on my 4000..... ...
Russ
11-07-2001 19:43:20
 Re: Re: Head bolts on 4020 in reply to Steve II, 11-07-2001 15:07:14
It isn't necessary to replace the bolts but I would recommend replacing the washers on the bolts.Also torque the bolts in a circular pattern starting with the center bolt. You should have gotten an instruction sheet with the head gasket kit.
Duane Klinger
11-15-2001 21:19:42
 Re: Re: Re: Head bolts on 4020 in reply to Russ, 11-07-2001 19:43:20
The circular pattern isn't recomended by John Deere anymore.If you don't replace the bolts,which I think you should,be sure to clean the threads in the head and blow them out dry and clean before you place the head down.Do this or you won't be able to get a good pull down with the bolts.If you don't get the new pattern with the gasket email me and I will send you a copy.
