Deere-Mansur Planter from the 1800s
Chad Batts
11-06-2001 14:01:24
I have come across a Deere-Mansur Planter and it has a 1883 or 1893 patend. Does anybody have any information about this planter, it seems to have 2 corn units outside with a 2 pea units inside.
Larry
11-08-2001 12:31:10
 Re: Deere-Mansur Planter from the 1800s in reply to Chad Batts, 11-06-2001 14:01:24
I noticed no replies so will try to help. I'm assuming the 1880's date you found on underside of planter box lid. Check several things for me and I can help better. 1. Does it have a marker pole on each side or 1 long wooden marker behind seat? 2. Does it have 4 rollers on each check head or only 2? 3. Look at braces that go to front of runner. Does it have 2 pieces of flat iron that bolt on or a wider cast piece that goes out to point. Any part numbers would be helpful.
